gmarshall43
- May 5, 2002
- 201
I'm working on a 1954 10hp Johnson. It will start and run ok at first but the RPM's will go up and down and eventually stall. I took the cover off and notice gas dripping out the carb had a milky look to it. Thinking the gas might be bad I tried it on a different motor and it ran fine. I cleaned out the carb and took a air hose to it and blew it all out. Put it back on the motor but it did the same thing. What would cause this?
Gary
Gary
