I have a Bayliner Capri with the Volvo Penta 125A motor in it. I recently posted on here because the copper coolant pipe which goes from the water pump to the strainer was leaking around the seal. I installed a new gasket and added extra support to the bolt under the pipe that helps hold it up. Motor fired right up and everything seemed fine aside from a small drip leak from the other end of the pipe going into the water pump. Wanting it to be perfect, I disconnected it, put new gaskets on that side, and ran a little liquid seal around the outside. Gave it a few days to dry, fired it up today and everything seemed fine, until I noticed a trickle of smoke coming from the strainer lid. Took it off and found the strainer bone dry, as was the pipe running from it to the water pump. The pump is brand new, have no idea why it wouldn't be working, the was water in it that I could feel when I stuck my finger in the outlet after disconnecting teh copper pipe. Haven't taken the pump completely off yet, when/if I do, what should I be looking for aside from a ground up impeller. Like I said it is brand new, not sure why it would be broke already.
