Re: Need help identifying two missing screws on 1968 johnson 9.5
It's a regular screw, There are 4 screws that hold the float bowl on, 2 long ones and 2 short ones, you are missing one of the short ones. If you remove the other short one on the starboard side of the carb you will see what you need. As for your bog issue, when was the last time the motor ran? has the carb been taken off and cleaned recently? Your symptom could be a result of a number of issues but I'd put a dirty carb at the top of the list. I had the carb off of my 66 a few days ago for cleaning and it was a piece of cake, not complicated at all.
