I am replacing my spark plugs and have a question. Motor is a 1980 Chrysler 85. My Seloc manual calls for Champion L20V with no gap noted in specs. When I pulled the plugs in there now they are L76V gapless. They were black and oily. The Champion website calls for L82C which I believe are standard gapped plugs.
Questions are, which plugs should I use? If I use the L82C do I just use the gap they are pre set too?
Also, I know Champions heat range increases with higher numbers. Manual L20- Current L76- website L82. This seems like quite a jump?
Thanks!
Thanks!
