where is the linkage disconnect from so i can drop the lower unit?
R ruffoceans Recruit Thread starter Joined May 26, 2009 Messages 4 Jul 20, 2012 #1 where is the linkage disconnect from so i can drop the lower unit?
metriccrescentwrench Commander Joined Oct 22, 2007 Messages 2,598 Jul 20, 2012 #2 Re: 120 hp looper 1994 changing the water pump It's hidden underneath the carbs. Look up your engine at shop2.evinrude.com , go to the "cylinder & crankcase" diagram and you'll see it.
