How long should I run wide open
bowmanhere
[SIZE=4HI I have a 1969 johnson 4 hp 4w69b out and it runs great so far since i changed the fuel pump , this is what I need to know ,how long can I run it at top speed safely, and also how long can it run real slow? this is what I do now if I am just putsin around then I open it wide 4 a bit but 4 4 how long can I do that ? any feed back would be great Thanks
HighTrim
Re: How long should I run wide open
When tuned properly, you can run it at either speed until the fuel runs out :)
Notice the disclaimer, "tuned properly"? That is water pump functioning as it should, ignition tuned, carb functioning as it should, etc...
That being said, I never run my outboards WOT for extended amounts of time, back off the throttle, and run at a cruise speed, saves on fuel.
boobie
If the mtr is tuned properly and you are using the correct fuel/oil mix you can run it all day at WOT or Idle.
B-Dozer
I had a 72 6hp evinrude i used for years as a teen and i would run that thing wide open for 3 hours at a time with like 3 guys in a 18ft flat bottom. Never had a problem with it on low idle or full speed !
Daviet
If the engine is propped correctly so that it will not over rev, you can run it at WOT as long as you want, your fuel useage will suffer.
bowmanhere
wanna say thanks 2 u all , Admiral what do u mean by over reving?
boobie
To keep it in the factory spec operating range for the mtr. You don't want to go above that.
Chinewalker
Also, UNDER-revving can be just as bad. Lugging a motor is akin to driving uphill, in fifth gear, while towing a trailer - ping-ping-ping! As was noted, proper propping is very important. If this is a lightweight tinny, then the standard issue prop is likely okay. If it is an auxiliary motor, then a lower pitch prop might be called for.
Davem3
WOT= empty gas tank and clean and happy motor..............i run mine at WOT whenever possible to clean out the carbon
bowmanhere
Ok u guys I got it , thanks you all and tu 4 the help all good things 2 u all:)
