Re: 1998 Force 75 hp fuel pump and carb rebuilt question
Hi dt4ever,
I have the same motor.
Yes you will have to do a “link and sync” after you clean the carbie. Easy to do on this motor as you only have one carbie to worry about. You will need to remove the idle adjustment screw to clean the passages in the carbie. Take photos as you go and you will be fine. Use a small amount of low strength lock-tite on the bolts for the fuel pump to prevent then from vibrating loose. I need to fit a new kit to my fuel pump tomorrow. I could post some picture if this would help. If your motor is running well at the moment the carbie is likely to be clean. That said I still clean my carbie each year.
While you have the carbie off check the fuel enrichment solenoid. You will need to disconnect the hoses that go from the solenoid to the carbie anyway to service the carbie. Blow down the hose that leads to the intake side of the solenoid and it should be blocked. Then push down on the black button on top of the solenoid and it should open and let air through. Check that the solenoid works when the ignition key is pressed in. You should hear a clicking sound.
The other common problem with the fuel enrichment solenoid is that the rubber grummet on the bolt that holds it to the motor wears over time. This allows the wires supplying power to the solenoid to rub on the intake manifold causing them to short and eventually to break. I caught mine just in time to save them. The wires get greasy and appear black but one of them should be yellow. Clean then up and have a look. This problem can cause difficulty in starting a cold engine. The rubber grummets are cheap. I purchased mine from an auto store. 10 in a packet. Now have enough for years!
Some photos of the fuel enrichment solenoid.
The venturi in the carbie is meant to face this direction. I checked with the manufacturer. You don’t need to remove this tube to clean the carbie so just leave it where it is.
Good Luck
