Hello all, been lurking for awhile, thanks for the great info.
I have a 1980 Chrysler 85 on a Glastron bow rider. I had the carbs cleaned out by a boat mech and he checked compression and it was great. I also emptied gas tank and added fresh pre-mixed 89 gas
My problem is that twice I have taken this boat out and cruised for hours at 5mph or less with no problems. Then I will go into the water ski area to open the boat up and it runs great. Full throttle to around 30mph. Then after cruising a little while longer I will put the boat in idle either to get trailer or to fish for a bit. Both times the boat died while idling. The first time I was in the open ocean. When I try to restart the boat it will not stay on and idle. My gear shift has a lever to disengage the prop so I did and gave it gas and it would start and run but when I would go back to idle it would die again. After numerous attempts I was able to quickly shift into forward and get under power. The motor ran really rough for about 5 minutes before I heard it smooth out. I then ran it at full throttle again and when I got back to dock it died while idling. Both times I had to row the boat onto the trailer.
Any thoughts? Previous owner said the impeller was replaced recently. A buddy thought it might be overheating? I don't have a temp or tach gauge.
Thanks for the help!
