Aq125a 270OD. I have a leak at the raw water pump. I replaced the seal on the shaft. But still have a leak. I did not use lube on this seal. Could it have started leaking again al most instantly. Or am I missing something?
Could a leak at this point cause the system to draw air and not cool properly?
Thanks for you help and any suggestions.
Eddie. P.S. Thanks again for all the help.
