Hello all, My motor is bogging real bad under wot and under a load. i have replaced the fuel pump, plugs a coil and a power pack, and it still runs like crap. it seems to run fine on the muffs but not in the. i have also cleaned the carbs. all the butterfly valves are open when the throttle is wo. It revs up fine in neutral. i had it out a few days ago and for 3 min it ran like it should then all of the sudden it started to bog down again. Please help i am at a total loss and have no other ideas on what could be causing my issue.
