night34606
- Jul 18, 2012
- 12
OK I have a SportJet 175 that started and ran a couple a weeks ago on the water fine. Tropical storm hit and I couldnt get her covered plus drain plug was slow from some grass apparently. The ran actually filled part of the boat, I took about 6-8 maybe 10 inches in the engine area. The water did not sit long once I noticed it in the storm I got the bilge pump running and cleared the drain so it was clear and only sat a couple of hours at max like that.
I waited till she was dried out and went to start her. Start seemed to lack power. Switched out the battery to a new one I bought since I was about to move to 2 batteries for the season anyway. Started seems to only partiall try, tried giving her a tap seemed to help a bit but its not even fully turning over to try and fire maybe half to 1 maybe 2 rotations. I also switched the positive and ground cables since the connections seemed a little rough.
Im not sure where to fully start looking even and would appreciate some help. I work on cars all the time and I would say it was a bad starter or a seized engine but she ran fine till the water issue. I was under the impression this kind of water level could be handled by a boat (not ideal but could be handled). Looking for some suggestions on where to start please.
