2000 260 Sea Ray Sundancer 5.7EFI Merc Bravo 3 (220 hours).
I damaged the lower casing last October. $4 grand for R&R the entire drive, new upper/lower gaskets/magnesium anodes, fix both SS props.
I'm upset it took my mechanic from early April until June 9th to get the boat ready for the water. One story about being busy after another. Finally we get to use the boat. As I trim the drive, I get two audible alarms and the entire system (electric and mechanical) hiccups/hesitates and then gets back to business. Perhaps the trim sending unit?
And on top of that, I now run through a resevoir of gear lube on a Saturday afternoon and find it in the bilge. It takes about 5 of the oil soak up rags sold at West Marine to clean it up (all contained in the bilge - no rainbows in the water).
I had a smaller friend climb in and trace the lube hose back to the transom. That's where it appears to be leaking. So repull the drive and get the hose connected. A two hour job?
Is this something that should have been detected when the drive was removed? Reconnected poorly or just coincidental?
My mechanic says we should pressure test the drive to find the leak and he wants to wait til the end of the season when we winterize. I can't do that.
I'm afraid to take it back to this guy (he's the onsite mechanic and the marina management doesn't allow outside mechanics to be brought in unless I pay the $150 surcharge).
Before I loose all faith in this mechanic and take my business elsewhere... should he have inspected the 90* plastic part and c-clip where they connect at the transom? Or am I too critical?
Thanks for reading.
Thanks for reading.
