If there is a trick to this I'd love to know. I've been tring to reinstall my lower gearcase for 2 days and it stops when the shift rod hits the bottom of the powerhead. It is almost 1/2 inch off of the hole I've put a little screw driver behind it but it wont budge. It is like it is hitting something and won't go any further forward toward the hole with the grommet.
I even attached a wire and fished it down through the grommet and through the lower unit and through the hole in the shift rod and carefully pulled it up as I put the gearcase back into the motor but no luck. I've tried forward and reverse. I've tried rotating the shift rod and can get a little closer if it is sideways but not close enough. Help!
Thanks,
DC
Thanks,
DC
