5.7L EFI Tune Up
John Evans
5.7L EFI GM 350 V-8 1998/0L010035_0L325976
What parts should I need for a tune up? What standard checks should be done?
Thanks in advance for you help.
Don S
Re: 5.7L EFI Tune Up
Should include a proper Compression test.View attachment 97-25 Compression Test.pdf
Cap, rotor, spark plugs. Verify timing, clean flame arrestor, fuel filters, basic check of engine hoses and electrical connectors for damage, corrosion, etc.
On EFI engines, I always like to hook up the diagnostic computer and check that all systems are reading normal. Especially things like ECT that could be off but not set a trouble code.
