Mac_55
- May 24, 2010
- 19
1991 120hp Johnson
took the boat out today for a run a solid alarm started the second the engine was running,
tach was working fine
lights and trim tilt worked fine
everything was good except the voltage increased on the gauge the faster i went up to 15V until i used the trim then it would bounce down to 13V and the alarm would stop until i let off the trim button and it would hit 15V again and alarm would start
just a solid alarm kinda like the one for overheating but the impeller was last year and the alarm started when the engine was started and increased in RPM
im thinking regulator/rec or bad battery ???
thanks
thanks
