tripn1will
- Jun 17, 2012
- 10
I have a 1989 5.8 omc with ford engine. when I crank the engine it fires as if starting then dies. When the switch is in the on position, I do not have power to the coil. I traced what I think is the hot wire (purple w/ white stripe) back to the starter relay and there is no power coming out of the relay. I replaced the switch but did n ot solve the problem. I checked all the connections I can find and replaced the 50 amp in line fuses. On a perhaps unrelated note, since I have been messing around, my motor for the out drive does not get power. A mechanic friend bypassed something to allow me to raise it to trailer the boat, so I know the motor works, it just is not getting power. I am stuck. Any ideas?
