Im getting my boat ready to put in after deck rebuild, Went over the engine to freshen it up while it was out. I test run it on the trailer with the drive in a barrel. At idle how much water flow should i have through the raw water screen and through the heat exchanger? Right now I just have a little flow, just kinda glugs a little water at a time, but as soon as i open the throttle a little, the water instantly picks up and fills the strainer with good flow through the exchanger.
Trying to figure if i have a air leak problem.
