Re: 5 1/2 HP Fisherman fule line
Is this a two line pressure tank set up or a single line?
Does the motor have a fuel pump?
If it is a pressure tank set up you have to search for a used tank, and probably rebuild it.
You could also convert it to a fuel pump set up and get a standard tank and line for less than a pressure tank set up.
Welcome to iboats.
