Have a 88 Blue Water with a 4.3L Mercruiser Alpha one, Gen. one. <br /><br />Just found out that my lower unit is trashed. Drive shaft bellows had lots of water in it, ujoint rusted and stiff, and gimble bearing is shot. After getting the gimble bearing out, I noticed the rubber seal in front of the gimble bearing was compressed on the top, didn't think much of it, untill I installed the New gimble bearing and inserted the engine alignment tool and the end of the tool was hitting low on the splines. Didn't matter how high or how low I adjusted the front motor mounts, I couldnt get the the engine coupler splines to come down. I greased the alignment tool and I can push it all the way in, but it puts the gimble bearing in some what of a bind. This alignment was probably off before by the looks of the compressed rubber seal.It's as if the fiber spacers between the rear mounts are to thick. <br /><br />I'm thinking that if I could lower the rear mounts a 1/16 to 1/8 inch. It would solve the problem, but thats about the thickness of the fiber washers.<br /><br />Anybody run into this???<br />Any ideas???
