polarisman_20
- Jul 16, 2012
- 7
I have been searching all over and have found different scenarios but I am finding my symptoms are different:
1993 Four Winns Horizon 190 Bow rider
5.0 OMC Cobra Engine/Outdrive
OMC Book says desired Operating RPM at WOT 4000-4400 RPM
I just bought the boat and he said it was tuned up 5 yrs ago. He was the original owner. The boat had a 14"x19P prop (not sure of make) on it and would rev almost 5000 RPM and just over 35 MPH. This was with 3 people and almost full tank.
I switched to a Michigan Wheel 14.25"x21P prop and the boat will still rev 4700 RPM with 4 people and 3/4 tank of fuel. The boat still barely runs just over 40 MPH. If I throttle back to 4500 RPM the speed is closer to 30-35 MPH.
Both Scenarios are trimmed just under the 3/4 mark on the gauge as any closer to 1/2 it will porpoise.
When I read online usually it is not enough RPM and a tune-up is suggested with a smaller prop. I am afraid to go to a 23 P prop as I plan to pull skiiers as well.
Why the high RPM's and Low Speed?
Thanks
Thanks
