  #1
Old May 19th, 2004, 11:53 AM
acc acc is offline
Default Aluminum boat in saltwater
Moving to Destin....I have an aluminum BassTracker that has been used only here (Huntsville) for freshwater fishing. I'd like to take it down there and use it as a bay boat during the winter months.....Will the aluminum construction withstand the corrosive saltwater environment.... I will not be berthing the boat in the water.Thanks
  #2
Old May 19th, 2004, 12:41 PM
quantumleap quantumleap is offline
Master Chief Petty Officer
Default Re: Aluminum boat in saltwater
Rinse it well each time you take it out. A pump type sprayer (like the ones used for weeds or deck waterproofing) works well if you don't have access to fresh water.
  #3
Old May 19th, 2004, 01:07 PM
ddaigle ddaigle is offline
The aluminum boat will be fine, whats going to cause you problems is everything else. The trailer, motor, trolling motor, electrics etc. are probably not saltwater models and salt water is really rough on these things. You will need to keep everything washed with fresh water and protected as much as possible with anti corrosion products. Look on other forums here such as trailering for good advice on preventing rust.
  #4
Old May 20th, 2004, 06:19 PM
Forktail Forktail is offline
Ensign
The most popular boat here in the salt are aluminum's. That's all my fleet is...custom made aluminum's. After 10 years you can de-oxidize the hull to make it look better if you want. Zink plate helps. But they'll usually outlive the captain.
  #5
Old May 20th, 2004, 07:44 PM
moderator1 moderator1 is offline
Moving to Boat Questions.
  #6
Old May 21st, 2004, 11:08 AM
susan61 susan61 is offline
ACC......My Bass Tracker has only known salt water for the past six years. No real problems as I wash down with fresh water after use and flush the outboard. Aluminum is so much easer to launch and recover than fiberglass, plus Aluminum only requires half the horsepower to do the same thing.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Aluminum boat - Saltwater corrosion repair reelfishin Boat Restoration and Building 8 April 5th, 2007 03:16 AM
Aluminum boat in saltwater coachtom2183 Boat Topics and Questions (not engine topics) 5 January 10th, 2007 08:01 PM
Aluminum boat in saltwater acc Non-Repair Outboard Discussions 4 May 20th, 2004 07:44 PM
aluminum boat and saltwater. GOOD OR BAD?? HELP!! RICHY Boat Topics and Questions (not engine topics) 6 July 6th, 2002 04:22 PM
aluminum boat and saltwater. GOOD OR BAD?? HELP!! RICHY Boat Topics and Questions (not engine topics) 3 June 30th, 2002 06:12 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
