I will start by saying i am sorry if i mis-categorized this thread but read on and let me know what you guys think:
I have a 79 wellcraft sunhatch with 198(5.0) gm mercruiser engine with matching MC-1 drive, everything appears to be original to the boat. With that being said i am having issues with my trim system and dont know where to start.
1.)i know the motor needs a solenoid as one post is broke out
2.)i can lift it by hand without much force and it wont stay up
3.)i have no visible fluid leaks and when i bought the boat i was able to trim all the way up by using a starter solenoid off a ford truck and it stayed up until i got it home , after 2 or three days its was all the way in the down posistion and is acting as described above
-do i look for leaks? do i get new cylinders (i know that there is no way of telling if something is broke inside the cylinders without disassembly) or do i go for broke and try to upgrade my trimp system all together with a newer model set up (if at all possible without heavy modifications?)
thank you all for reading and again to the moderators i just didnt knjow where to place my thread as it does pertain to my drive and is mercruiser?
-Jim
-Jim
