1985 dt 200 good water pressure at wake speed,but no water pressure at idle alarm sounds.
P Pickingsix Cadet Joined Jul 7, 2002 Messages 6 Aug 4, 2002 #1 1985 dt 200 good water pressure at wake speed,but no water pressure at idle alarm sounds.
Kiwi Petty Officer 2nd Class Joined Jun 7, 2001 Messages 155 Aug 4, 2002 #2 Re: suzki dt 200 cooling problems at idle Sounds like it might be time to have the water pump impeller checked/replaced.
S Spidybot Lieutenant Commander Joined Apr 4, 2002 Messages 1,734 Aug 5, 2002 #3 Re: suzki dt 200 cooling problems at idle And check the thermostat while you're at it.
P Pickingsix Cadet Joined Jul 7, 2002 Messages 6 Aug 10, 2002 #4 Re: suzki dt 200 cooling problems at idle Thanks
P Pickingsix Cadet Joined Jul 7, 2002 Messages 6 Aug 10, 2002 #5 Re: suzki dt 200 cooling problems at idle Thank you Kiwi for the help on my motor.<br />Now if I can just get the impeller shiped.<br />we dont have a suzuki dealer in alabama.<br />By the way I had to change the head gaskets. <br /><br /> thanks Pickingsix
P Pickingsix Cadet Joined Jul 7, 2002 Messages 6 Aug 10, 2002 #6 Re: suzki dt 200 cooling problems at idle Thanks UU<br />It was the impeller.Haveing trouble geting the new one.Had to replace the head gaskets also.
W wilde1j Vice Admiral Joined Apr 15, 2002 Messages 5,964 Aug 10, 2002 #7 Re: suzki dt 200 cooling problems at idle Don't just replace the impeller if there's any doubt about the pump body/liner and wear plate. Any scoring in either is cause for replacement.
L lakensea Chief Petty Officer Joined Jan 30, 2002 Messages 542 Aug 11, 2002 #8 Re: suzki dt 200 cooling problems at idle Pickingsix,<br /><br /> You have 5 Suzuki dealers in Alabama. Go to www.suzukimarine.com, click on the dealer locater.
