Re: 33 hp Johnson doesn't sound right, video what do you think?
Hello again diveman. For starters, make sure you're running the correct plugs. Champion J6C are best. Both cylinders are feed fuel, more or less equally, so if one plug is particularly fouled it's probably not firing consistently which means you'll have to inspect the ignition. The fact that it happened after the motor warmed up is also a tell tale sign that you have an ignition/electronic problem. As the motor heats up, it causes the components to fail. You may also want to make sure the spark plug wires are twisted into place onto the coil posts rather than just poking them in place. If the plug wires are corroded, you may want to snip them back about 1/2" on the coil end to expose some fresh copper within. Btw have you inspected the coils? If they are scorched or cracked in any way they will need to be replaced as well. Of course a carb cleaning and rebuild is never a bad idea, but focus on one factor at a time. Once you have strong, consistent spark, adequate compression and fuel, it should fire right up. You can get a tune up kit with points & condensers as well as new coils right here at iboats for about $20 each. Keep us posted. Holler if you get stuck.
