Firstly I would like to thank this site and all the guys on it. This is the first post I have had to do because all of my troubles have been covered by others.
hears the deal... 1985 force 125
Out trolling a few days ago for about 2 hours ...3mph 1100 rpm everything is fine but no fish. The motor dies out so I restart no problem. When I went to put it in gear it dies out..repeat 3-4 times. I popped the top and fiddled with everything over the next hour. Idle stop screw, connecting rod, carbs. Nothing helps finally I did get it to run and idle in gear,(1000rpm) but everytime I tried to give a bit more gas motor died. Idled back to dock. Note : Motor would take gas manually with connecting rod off. .....Got home went to flush motor, starts fine and...get this...goes in and out of gear and revs fine.
My thinking ....is ..am I sucking air, that would explain start and idle being fine..or something electrical.
Checked all hoses
New diaphram in fuel pump 2 months prior
Timing set and carbs cleaned 2 months prior.
New feul tank
Compression is 140 on all 4
Any thoughts would be appriciated. Thank You
Checked all hoses
New feul tank
