timing a out sport jet 120 xr
Talonn1
Hi. I replaced the stator , trigger , voltage reg, and rev limiter. The boat runs, but I can't get the timing right. I run out of adjustment at around 20? . I've moved the stator around with the same results. I think my gun might be bad because the strobing doesn't actually "stop" the numbers
Its slows them down to kinda see them.
I have moved the stator with the wires from the 12 o'clock position to the 6.
Any help would be great.
