New manifold
superiormgmt
I'm putting a Hurricane intake manifold on my 5.7 v8 merc's. The problem I already see is the choke on the carburator.The new intake is unable to provide the choke. . Is there a solution for this? :confused:
Re: New manifold
Do you mean there's No pocket for the Choke Stove to sit in,......<br />Is that the Rochester,.??...<br /><br />My Carb. has an Electric Choke,..... No stove Needed.......<br />It's the Merc/Weber 4bbl.......
Re: New manifold
And,.... No,... I Don't know if you can Convert a Rottenchester to Electric Choke.........<br />Though it does seem Probable........
superiormgmt
Re: New manifold
yes, its a Rochester and needs a choke stove. Whats the difference in on a electric
Re: New manifold
When you turn the key On,.... It powers a heater in the choke box on the side of the carb,+ starts Pulling it off........<br />The wire is alway Hot, when running, so the choke stays Off after a Few minutes......
