MC-1 with Prestolyte trim pump
1. Trim motor will turn on in the up and down position
2. I've disconnected the hydraulic lines at the cylinder on both sides and confirmed fluid is being pump in the up and down position and that they are in the right spots.
3. The outdrive will go up perfectly with no problem.
I have searched for a few hrs now to find a hyd diagram to see if there is a valve or some thing that would stop fluid from returning to the reservoir when down is selected but can't find one.
I check out the reverse lock (or whatever its called). I the control lever in reverse and was still able to trim the drive up but not down.
Am I missing something simple!?
Don, I am sure you can help me with this. Either by directing me to a diagram or have experienced this before!
Thanks in advance.
Thanks in advance.
