jameskcowley
- Jul 3, 2012
- 5
My recent purchase has the above engine and I have scoured the forum for many threads about a tilt/trim issue but this leaves me still with a poser!
When not used for a couple of days, to get the stern down I have to ask someone to just lend some weight to initiate the movement - all is then well to fully down. However, the "up" motion initiates and moves for a few inches before the motor stops. I am then able to use the trailer trim to raise it.
If the stern is not fully down (absolutely down) the "up" trim doesnt work albeit the trailer trim kicks in.
I have concluded that the pump must be ok, the solenoids must be ok, the switch must be ok but.................
So... why does the sterndrive no auto matically go down when the "down" button is toggled and then why will it only come up a few inches on the "up" trim, even tho' the trailer button ensures itcan be fully retracted?
The only thing I haven't done is to bleed the system but the oil looks like oil (not milky white), the engine has been regularly serviced and through a combo of some weight to start, some toggling between up and trailer, I have a tiltable stern drive.
I have read up/down issues etc but none describing this problem and would really appreciate some ehlp.
Thanks ever so
James
Thanks ever so
James
