OutragousBob
- Jul 14, 2012
- 12
Hi I'm new here,
I'm trying to solve a problem with my 90hp ocean pro 60 degree looper. I have water getting into the lower port side cylinder. I pulled the head figureing I had a bad head gasket and found a few scores around the exhaust port. I installed new head gasket o-rings and did a compression check, I had 116lbs in the lower port cylinder. I put about four hours on the motor yesterday and it ran well at all speeds exept idle where it was rough. When I got home I pulled the plugs and again found the lower port cylinder full of milky water and oil. I checked the compression and it was showing 120 in the watery lower port cylinder. I pulled the head again, but I couldn't find a problem with the head gasket or head(it is not warped etc.). I'm at a loss as to where the water is getting in. Any ideas would be appreciated.
Bob.
Bob.
