Magnus Wallner
- Jul 4, 2012
- 32
I have a noise coming from my new to me boat with 1992 Merc 5,7 and Alpha One gen 2. I'm new to this whole outdrive thing so I'm not sure if it's normal or not.
The sound/noise is a little like that from a worn CV-joint or a timing chain tensioner failing. It's not a grinding noise and it's not a heavy clunking (like that from a con rod). There's no change in noise when I turn the wheel or apply load (points away from CV-joint) and by using the metal rod and listening to the engine it sounds all well. I can hear it from both the engine bay and from outside the boat, ie leaning over the stern.
So I'm thinking that it may be the gimbal bearing? What say you experts?
Should I continue to run the boat and see if the noise gets worse (assuming it's not normal)? If it is the gimbal or a CV, could it go from making a noise to sudden BOOM causing mighty failure of the whole outdrive/engine)?
Outdrive has been serviced with oil and impeller and there were no evidence of leaking or gear/bearing failing judging by the oil. No noise when turning the shaft and no grinding or resistance.
Thanks!
Thanks!
