02 Mercruiser 350MAG(Eng Ser#OM330551) MPI with a BIII(Stern Drive#OM128044)
I bought the boat last year with 120hrs on it and drive lube leak in the bilge. I had the boat serviced and the Shaft Seals and the bearin was replaced along with the Yoke Seal. After the 4th weekend I noticed the reservoir was down past the low level mark. I filled the reservoir. Two days later while sitting onthe trailer in storage the fluid is low again? While towing home today, fluid started to leak from the drain plug which means the bilge is getting fluid in it again. What would cause those seals and bearings to go AGAIN in such a short time(Less than a 100hrs)? Keep in mind I have done no troubleshooting at this time. I plan to pull the drive tomorrow and see whats up.
