Re: 1988 115 hp merc stalling on de celeration
I bought the same engine new. Never had that problem. What is the maintenance/use history on the engine? Where I am headed is that with "back drag" carbs the timing is held at a fixed value and the carb butterflies are moved in the closed position......you punch out of the hole, get on plane and up to speed, say 38. Then you ease the throttle back and your speed drops off to say 35. If you had a fuel flow meter, you would notice that your speed dropped 3 mph but your fuel consumption may have dropped 20%. This enhanced the mpg. There was obviously a limit to how far you could cut the throttle before the timing retarded along with closing the carb's butterflies.
Another thought: Out of the water, or lower unit out of the water, engine off, shift into F gear and ensure that CCW turning of the prop offers resistance....to rotate the prop you will be turning the crankshaft. Turn it CW and it rotates easily and makes a clicking noise....that noise is your overrun clutch in your lower unit...your clutch dog that your shift linkage moves forward and backwards along the prop shaft to hook into the F gear which is up front in the LU or R gear which is at the rear part of your LU.
If the overrun clutch isn't functioning, your boat should come off plane very abruptly, and it would be loading the engine really big time because instead of the prop free wheeling, being driven by the rushing water, not the engine, it is locked to the engine and is keeping the engine up and running in rpms, but you just strangled it by cutting the throttle. Doing that while you are manually cutting the throttle would kill the engine.
Keep me posted.
Mark
