2000 johnson oceanpro 90hp low rpms at idle
inxkn
my motor is running at around 8000 rpm's in neutrel and it drops to about 6000 in gear and it keeps stalling out unless i hammer the gas. I need to adjust the idle up but on a motor with 4 carbs I don't know what screws are which any help would be helpfull. Thanks
Chris1956
Re: 2000 johnson oceanpro 90hp low rpms at idle
I presume you mean that it idles at 800 RPM in neutral and 600RPM in gear? The idle speed on that motor is controlled by the timing. A service manual will describe how to set it and what it should be set at. There is a little plastic tab on the flywheel that is moved to adjust the timing. of course, you need to know which one is for idle and which is for max spark advance.
inxkn
yes sorry my mistake it 800 and 600 where is the best place to get a manual for this motor
Chris1956
I ordered mine from the marineengine website. Have your model number handy. There are other web sites that will have it as well.
