I have a 2006 suntracker 22' regency with a 135 HP
3.0 mercruiser alpha 1. I was wanting to try a composite prop and an online boat mechanic said I needed a 14x19p. Does that sound correct ?
Welcome to Iboats.
Unless you gave that "on-line boat mechanic" specific info about your current prop, speeds, and engine RPM's, his information is just here-say.
What does your boat currently have for a prop (pitch, diameter, blade count, material)? What speeds are you attaining at WOT (GPS is best for measuring this)? What is your engine RPM at WOT?
Also wondering why you want a composite prop when aluminum props are fairly cheap, and more durable.
I think a 19 pitch is wrong. The numbers you just posted indicate a properly propped boat with that engine, the slip may be a little high. Is that a pontoon boat? Do you know the drive ratio?
Not composite worst prop for your application..Unless you boat in waters full of hazards.
The Solas Amita 4 blade has a good reputation.What aluminum prop brand or type would be best for my application
