cap'n james
- Jul 5, 2012
- 3
To make a long story short, I bought a boat (1960's vintage) and was told that it ran. I have been working to verify that it does run and have found that the enginge (gm 4 cyl 110 s/n:1633204) runs well, but the drive unit (120/140 decal on the side) had been somewhat neglected. The propeller shaft turned freely, but the lower unit gear oil was milky, so I drained it, pulled it, and found that the drive shaft was pitted and corroded. Also, there was some damage to the gear case housing itself that someone tried to fix with bondo or epoxy putty. A new drive shaft seems to be $200+, and even if I could replace it myself, I have that hole in the housing to fix. I have seen a number of lower units on ebay from $3-500 - is that an option? I am concerned about compatability, especially where the gear ratio is concerned.
My best guess is that I have a merc - I outdrive. I haven't found any serial number on it but I can say that it is a manual trim unit, and it does have the vent hole by the water pump.
Thanks in advance!
Thanks in advance!
