evinrude 28spl wont start with key but will pull
leohrtd1
have been trying to get this one straight for some time. i can pull start it runs good can take out one plug and key will turn it over. have checked the starter good to go just bought new seliniod still same problem sounds like the battery is dead but has full charge. i dont have compression tester just trying to figure this out , bad wire, headgasket or where do i go from here just wanna go fishin.
boobie
Re: evinrude 28spl wont start with key but will pull
Have the battery load tested and then clean the battery cable connections on both the battery and the mtr. How did you check your starter ??
Daviet
You might want to have your battery load tested. Check all the electrical connections starting at the battery cables. You might want to do a voltage drop test on the battery cables to make sure they are ok internally.
boobie
I think I said that.
Daviet
At exactly the same time.:)
boobie
You got that right. LOL............
