rowinggirl
- Jun 20, 2011
- 2
This is a 1999 Evinrude 70hp - have to have the warm up lever up to start even if the engine has only been off for a couple of minutes. We did have a faulty thermostat that the mechanic took out and said wasn't needed. So currently no thermostat in it and this issue still exists. also, we have cleaned the carbs, replaced the fuel pump and installed a new fuel line. Engine runs great at idle but as soon as I put it in gear, either forward or reverse, it sputters and wants to stall out. Runs good at higher speeds. Ideas anyone? Is this related to there being no thermostat or is there something else I should be looking at here?
