Re: fuel water separator
also, if you are running a carbed engine, according to Evinrude tech (sent them an email yesterday and they called me back... nice service) then make sure you are running 20+ micron filter. Most of the kits come with a 10 micron. According to them, although it'll run, and may even run well, that little extra drag on the fuel pressure can cause a lean condition and higher RPMs
For Fuel Injected you're fine with a standard 10 micron
