i need some help here please. I have changed the outdrive impeller and when driving my boat the engine will tend to overheat. There is no coolant leaking issue out of the circulating pump area. I am at a loss right not. Anyone have any ideas?
you need to get a service manual #8 it will tell you allYes the heat exchanger gets fairly hot except for where the raw waters enters it.
I saw a breakdown of the manifold and it showed the point down on the thermostat. The breakdown was for a 1982 thru 1986 470. I'm not arguing to putting out there what info I am finding.
When I back flushed the exchanger the water seemed to flow fairly good.
How do I check for back pressure with the boat sitting in the water? Disconnect the hose going to the exhaust manifold and put the hose there?
i will have to agree you got something restricting the flow i wonder if you have a 3" or 4" exchanger and i will also say your impeller housing could be shot did you give it a good inspection when you changed the impeller. when the housing never gets changed it also wears out from not being changed and when you changed impeller the housing being worn out does not create enough suction for proper cooling. yes the pointed end of the thermostat points downThere are a bunch of tubs in there and if there is stiff like impeller pieces in there backflushing would just move them out of the way, and when water started flowing the other way they would just get caught again. There is a good chance there is nothing in there, but you gotta check.
Yes. I would raise the outdrive up as high as I could to try to get it out of the water as much as I could, just stick the hose end on the fitting, should not be much backpressure.
