93 9.9hp 2 stroke
Replace gaskets and impeller with new one. Turned shaft by hand when bottom housing off and hear a pop pop noise as impeller turns. The key and washers were replaced
I took the thermostat out and not water is being pumped out!! Check to make sure tube was in tube guide
I am stumped. Any suggestions would be greatly appreciated
Hope some one can help out
Thanks
Thanks
