115hp mariner idle problem
deanz115
Hope someone can help me with a problem. I have a 1985 115 hp mariner outboard. its an inline non dist 6 cyl. I cant get it to idle under 1,000 rpm. I've replaced the carb floats (had one bad), fuel inlet needles, cleaned and blew out the carbs, replaced the plugs, replaced all the gas line , primer bulb, and fuel filter. It has good gas and the fuel pump seems to be ok. I timed and synched the carbs and ignition. It starts and runs great, i just cant get it to idle at rpm that the manual states which is 500 to 600 rpm. I've adj the idle screws but it doesnt help. I noticed when i was replacing the plugs i checked the compression(110+-3psi) that i didnt have any fire on the 2,4,6 cyl. I'm assuming only 3cyl fire until it starts up or it wouldnt run as well as it does other than a low idle problem. I also checked the fuel pump and it also seems to be ok. If i still have the ignition timing off a little, would it give me an idle issue? I'm running out of things to check.
canoemang
Re: 115hp mariner idle problem
All 6 are supposed to fire at all speeds. it isnt a 3 + 3 :)
You may want to run some dva tests on your ignition.
even if all 6 are firing reaching an idle rpm out of gear at 500 or 600 rpm is gonna be tough, maybe in gear.
Chris1956
After you get all cylinders to fire, you can set the idle speed. Turn the idle stop screw on the throttle arm CCW and adjust the throttle cable to push the throttle closed. Add some preload to help you find neutral.
deanz115
Thanks for the info. I'm going to put it on the water this weekend. Then get it warmed up real good and check the fire on all the cylinders. If that checks ok, i'll try to adjust the carbs for low idle. I'll let you know how it goes. Hopefully good.
Charlie61
it may be one of switch box is going bad see if your getting voltage to your coils on 2,4, 6, one side to ground other to wire from switch box
