Re: New Water Pump - Still not pumping water
Hello - I much appreciate your help.
Here is what I have done so far on my 1984 Evinrude - Model E35ELCSM - 35 hp.
In the past I have always put earmuffs with a garden hose with full pressure and started the motor prior to putting it in the water. It had always peed water out of the bottom of the motor.
Last year, when I tested it, it did not pee, so I assumed that the water pump impeller had deterioriated. I installed a new water pump kit including a new housing, impeller, all the various gaskets, o-rings, etc. as per the instructions. All appeared to go fine with the installation; however, I did have a little trouble hooking up the rubber hose to the copper line. I finally did get it lined up and secured.
Then I did what I normally do with the muffs and garden hose; however, it did not pee as it had before. I did not want to keep it running and get the engine hot so I only had it running about 2 or 3 minutes with no luck on it pumping water. I do have the intake fins in the proper position. I also cleaned out the hose from the pee hole to where it connects onto the engine with compressed air and it blew clean - no obstruction.
That's what I have done so far.
Al Drang
