Re: Mercury 25 HP 2 stroke slipping out of gear??
To help us help you you have to learn the proper terminology. Sorry, but we only respond to what we are told.
Ventilation is when the prop sucks in air in combination with the water it is supposed to be pushing. Since air compresses and water doesn't, any air causes the load on the engine to drop which allows it to unload meaning that rpms increase directionally proportional to the load that has been relieved.
Trim, props, bottom of the boat conditions, hull shape , weight, weight distribution, water conditions, engine prop vs water level height, on and on and on, all contribute to the unknown "performance equation". It is really a complex operation, for higher performance operations especially, and has to be walked through step by step. As I said below, the best thing you can do is find a knowledgeable friend that is water savvy and have him get involved in your rig and help you to maximize the performance and get you the "fun machine" that you spent your money to obtain. You can talk to us all day, but unless we are there and witness the reality of your situation all we can do is guess. Sometimes we are lucky, other times just shooting in the dark.
HTH,
Mark
