Alpha one drive shaft yoke sizes for v8
Speed1v8
Hi I have a 2.5 mercruiser mated to a alpha one. If I swap a v6 or v8 small block I would have to change to a 9 1/2 longer yoke driveshaft is this correct or do I use the stock yoke witch is shorter. PleAse need help
Re: Alpha one drive shaft yoke sizes for v8
Ayuh,... Correct...
Speed1v8
Thanks bond-o seems like you only one helping
Speed1v8
What about the bell housing are all mcm motors have sAme bell housing
Ayuh,.... If yer referin' to the Flywheel covers,... Nope,... several different 1s...
All Chevys use the same bellhousin' flange bolt pattern though....
Speed1v8
Oh ok well that wraps it up for this one thanks
