Re: 1958 18hp carb high speed needle vibrates out
All,
Had the same problem and posted same question and got same answer. It did fix the problem!
But not knowing a lot I learned the following... (after crushing those ~1.00 felt packings on a couple carbs)
1) Assemble the needle, gland nut, and packing outside the carb. (Basically slide together in the order it reassembles.
2) Take the assembly to the carb and screw in the needle to basically all the way in.
3) then tighten gland nut to a decent tighteness.
Then unscrew needle to approximate desired location.
I am not sure if this is the "correct" method but I tell you I have not crushed a felt packing or had a problem with the needle rotating out while running.
This may be a no sh%^ type of thing but a lesson learned by me may save someone a few bucks.
Thanks,
Chris
