Chrysler Tracer Boat, Looking for info
kkz100
I've acquired a Chrysler Tracer 14' Boat, I think it is 1968. The tag inside it says 45HP outboard max, 900LBS capacity max. I think it feels a little heavy, I haven't put it in the water yet. How do I figure out what this boat is supposed to weigh? How easy is it for this boat's foam filling to become waterlogged? Is it easy to get the water out or replace the foam? I don't know if there is water in there but I'd rather compare the weight to the manufactured weight instead of cutting it apart. I think it is a neat little boat and I'd like to put some seats in and run it. I cannot find any information on this boat anywhere online. I'd like to see some other boats like this, possibly some pictures of restored boats. I'd like to try to figure out what the boat is worth.
Any help would be appreciated.
southkogs
Re: Chrysler Tracer Boat, Looking for info
Welcome aboard kkz.
It's not going to weigh much, but see if THESE GUYS have any information on it.
Pretty easy if the boat wasn't cared for.
Most of the time you will have to replace the foam - and it's quite a task.
To be honest: probably not too much. Old boats (save for a few particular types) don't appreciate in value like classic cars. You can't restore them and then recover what you've got in it. Most of the time, you work on 'em just 'cause you like 'em. The Chryslers will have a bit of a following, which will help - but don't expect big numbers.
kkz100
Welcome aboard kkz.
Thank you, I'll see what I can learn while I'm here and I'll probably contribute by helping others.
I already browsed that one and couldn't find the information I needed. I searched for a long time and viewed a page with information on a 1966 model year. I'd assume the weight for a 1968 model year would be similar. I found my information here http://www.allpar.com/old/boats-1966.php
The people that gave it to me said that they just drained the water before I arrived. It didn't have a plug in it and it was sitting at an angle so it would drain if leaves didn't fall into it. It seems very solid however, I'll have to weigh it on the truck scale at work to see how much water it has absorbed if any.
I assume that using yellow pressed foam board is out of the question as the poured foam probably adds to the hull strength.
I didn't expect to sell it but I needed to know what it is worth to pay sales tax on it when I register it, since it was given to me. I don't want the Department of Natural Resources to come up with an absurd number that I have to pay for estimated sales tax. I wanted to find some proof that it isn't worth much. But its like you said, its a neat boat for me, it means something to me to fix it and use it and I'll have some fun with it even if I don't get any money back out of it.
southkogs
Gotcha' ...
As for the value of it for taxation the DNR: $300. It's a derelict project boat. Ain't worth more than that to anyone ('til you get it shined up).
As far as getting an idea if it's waterlogged: make sure she's secure on the trailer. Clean out the bilge area and make sure the plug is out. Get the nose as far up as you can - if you get water comin' out, it's a reasonable bet that you're waterlogged if she's been sitting uncovered for a long time. Dry weight on my 18' (without engine) is about 1,400#. Yours should be closer to 500# or 700# not including trailer or motor (as a rough guess).
roscoe
In this economy, the trailer is worth $150, and the boat about $50.
Does that boat even have any floatation foam?
