NeedaBiggerBoat
- May 28, 2011
- 46
Running high temps and possibly hooked up wrong.
Where is the fresh water inlet hose?
I unhooked the T fitting and cranked the engine and water came out of the port side riser if I am understanding this correctly shouldn't the raw water be pumped to the heat exchanger first and out the risers last?
Well I drained the coolant and held a hose to every single line on the thing everything seems fine I am stumped as to why its overheating. When it was hooked up to the hose water was flowing really good through everywhere. I just need some direction here as it seems like it is the last thing that needs fixed before my vacation. The coolant was bubbling and boiling out through the overflow it seemed at idle after a run down the lake.
