Re: Force 125 1985 prop nut is backing out
Listen to me: There is no hole for a cotter pin at the prop nut. The nylock insert is worn past its locking ability. Buy a new self locking prop nut and use it.
Now: Unless your lower unit was changed, there should be an extended prop shaft to take a flare washer and tailcone. While these two pieces will not keep a propnut from loosening, they will keep it from backing out completely. If you do not have these, there is a hole in the shaft through which you can install a large cotter as a safety so if the nut should back off, you still will not lose the prop.
If your lower unit was changed and you have the short shaft, you can find a prop with a Mercury style hub and use the mercury locking washer and propnut. Later force engines use them.
The small allen head screw, if it was about 1/2 inch long, was probably from the anode. Behind the prop there is a circulat zinc anode held by two screws. Usually they are slotted head fillister but someone may have replaced them with allen head.
