gvsu141
- Jan 11, 2012
- 8
I have an 1986 Four Winns with an OMC 5.0 Chevy. Has the petronix electronic ignitor in the distributor. The other day I was adjusting the carb to get the idle set properly. The boat was starting and running great except a small idle issue.
I turned the boat off, made an adjustment to the throttle linkage at the carb, then the boat would not start. Pulled the coil wire off, and found it had no spark from the coil.
I then found that when I removed the 2 grey wires from the [-] side of the coil, the voltage at the [+] side jumped up to 11 volts. Next, I disconnected the grey tach wire to check if that was grounding somewhere, still no change. This now means the voltage drops down when connecting the grey wire from the ESA.
I tried bypassing and disconnecting the ESA several different ways, and still could not get spark.
It doesn't seem like this voltage drop should be there. Any Ideas on what might be the cause of my issue? Bad ESA? Bad Ignitor?
Thanks!
- I tried grounding directly from the coil without the wire, still nothing.
- Checked the voltage at the [+] side of the coil. Ranged from 4-7 volts voltage is the same at both coil terminals.
- I tried using 2 other coils I had (one from the shelf, one borrowed from another boat) all 3 showed the same symptoms.
Thanks!
